Writer Directives
The suffixes shown are prefixed by the current <WriterKeyword> in a mapping file.
By default, the <WriterKeyword> for the C++ TFS Fixed Schema writer is TFS_FIXEDSCHEMA and the <WriterKeyword> for the Java TFS Fixed Schema writer is TFS_FIXEDSCHEMA_JAVA.
DATASET
The value for this directive is the TFS Fixed Schema file to be written. A typical mapping file fragment specifying an output TFS Fixed Schema dataset looks like:
TFS_FIXEDSCHEMA_DATASET /usr/data/tfs_fixedschema/output.tfs
Required/Optional
Required
Workbench Parameter
Destination Text Feature Store (TFS) Fixed Schema File
