Teradata Spatial (TPT API) Writer Parameters
Database Connection
This specifies the hostname or IP address of the machine hosting the DBMS.
Specifies the name of the Teradata Database. The database name must exist in the DBMS.
Enter the username and password to access the database, user account, or wherever authentication is required.
ODBC Connection
The ODBC Data Source Name to use for the DDL statements, i.e., create and drop tables. The DSN must exist and contain the appropriate login credentials.
