RDB_Project Quick Facts
Format Type Identifier | RDB_PROJECT |
Reader/Writer | Reader |
Licensing Level | Professional |
Dependencies | RDB, XML |
Dataset Type | File |
Feature Type | RDB_PROJECT |
Typical File Extensions | .rpp, .rsp |
Automated Translation Support | Yes |
User-Defined Attributes | No |
Coordinate System Support | No |
Generic Color Support | No |
Spatial Index | No |
Schema Required | Yes |
Transaction Support | No |
Encoding Support | No |
Geometry Type | fme_type |
Geometry Support | ||||
Geometry | Supported? | Geometry | Supported? | |
aggregate | no | point | no | |
circles | no | polygon | no | |
circular arc | no | raster | no | |
donut polygon | no | solid | no | |
elliptical arc | no | surface | no | |
ellipses | no | text | no | |
line | no | z values | yes | |
None | no | point cloud | yes |
Point Cloud Component | Data Type | Notes |
fmepc_angle | INT8 | ScanAngleRank (-128..127) in degrees. Only in P3D.rds version 3.0. |
fmepc_classification | UINT8 | Classification from LAS Standard 1.3. Only in P3D.rds version 1.1+. |
fmepc_color_r | UINT8 | From optional RGB file |
fmepc_color_g | UINT8 | From optional RGB file |
fmepc_color_b | UINT8 | From optional RGB file |
fmepc_flight_line_edge | not supported | |
fmepc_flight_line | not supported | |
fmepc_gps_timeUINT64 | UINT64 | Timestamp. Retrieved either from data file or optional TST file |
fmepc_gps_week | not supported | |
fmepc_intensity | INT16 | Reflectance or amplitude |
fmepc_number_of_returns | UINT8 | TargetCount. Only in P3D.rds version 2.2, 3.0. |
fmepc_point_source_id | UINT32 | SourceIndex. Only in P3D.rds version 2.1, 2.2, 3.0. |
fmepc_posix_time | not supported | |
fmepc_return | UINT8 | TargetNumber. Only in P3D.rds version 2.2, 3.0. |
fmepc_scan_direction | not supported | |
fmepc_user_data | not supported |
