Custom Line Styles
The custom line styles are stored as linkages of the element.
In v7, the custom line style name is stored in igds_custom_linestyle attribute. In v8, the custom line style name is stored in igds_style_name attributes. There is also an igds_style attribute that stores custom line style name ID (negative integer).
It is the user’s responsibility to provide the correct seed file containing the definitions of the custom line styles and to copy the .rsc file into the folder containing other Microstation resource files.
Here are the steps to configure Microstation for Custom Line Styles:
  1. Open the seed file or destination file.
  2. Select Workspace > Configuration > Symbology.
  3. Click Select.
  4. Select the .rsc file that you want to use.
  5. Click Add to add the .rsc file to the list.
  6. Click OK and then Done.
  7. Close the file and then reopen it. (It is important to close the file; otherwise, the recent changes in the configuration are not reflected.)
  8. From the Active Line Style pull-down menu, select Custom. Then select the name of line style that you want to use, and double-click to activate it.
  9. Select File > SaveSettings.
  10. Repeat with every line style you are going to use.
In v7, to write a custom line style, the user needs to set the igds_custom_linestyle attribute. In v8, a custom line style cannot be set by its name – instead, the user needs to set igds_style attribute, which is then used to match an existing line style definition in the seed-file.
V7 Required and Optional Values
Required igds_custom_linestyle
Optional
igds_custom_linestyle_rbit
igds_custom_linestyle_mbit
igds_custom_linestyle_ibit
igds_custom_linestyle_class
V8 Required and Optional Values
Required igds_style
Optional
igds_style_name
igds_custom_linestyle_flags
igds_custom_linestyle_scale
igds_custom_linestyle_start_width
igds_custom_linestyle_end_width
igds_custom_linestyle_distance_shift
igds_custom_linestyle_fraction_shift
igds_custom_linestyle_center_shift
igds_custom_linestyle_rotation
If you do not provide the optional attributes for either version, the writer will use default values.
Note: When translating from DGN to DGN where a complex chain in the source data set has custom line styles, then you have to set the keyword PROPAGATE_CHAIN_ELEMENT_LINKAGES to true to translate the custom line styles properly to the destination format.
If a complex chain has different line styles, in order to retain those line styles, set “Drop Complex Chain” to yes.
