Reader Directives – Personal Geodatabase
The directives listed in this section are used when connecting to a Personal Geodatabase (.mdb
or .accdb
file).
DATASET
Required/Optional: Required
The file (Personal Geodatabase) or folder (File-based Geodatabase) from which data is to be read.
For Personal Geodatabases, an .mdb
or .accdb
file is specified when connecting to a Personal Geodatabase.
For File-based Geodatabases, a folder ending in .gdb
is specified.
Personal Geodatabases Example:
GEODATABASE_MDB_DATASET ”C:\FME\personalGeodb.mdb”
File-based Geodatabases Example:
GEODATABASE_FILE_DATASET ”C:\FME\montgomery.gdb”
Workbench Parameter
Source Esri Geodatabase (File-based) File
SEARCH_ENVELOPE
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that interact with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE <minX> <minY> <maxX> <maxY>
Note: If all four coordinates of the search envelope are specified as zero, the search envelope will be disabled.
Required/Optional
Optional
Workbench Parameter
Minimum X, Minimum Y, Maximum X, Maximum Y
SEARCH_ENVELOPE_COORDINATE_SYSTEM
This directive specifies the coordinate system of the search envelope if it is different than the coordinate system of the data.
The COORDINATE_SYSTEM
directive, which specifies the coordinate system associated with the data to be read, must always be set if the SEARCH_ENVELOPE_COORDINATE_SYSTEM
directive is set.
If this directive is set, the minimum and maximum points of the search envelope are reprojected from the SEARCH_ENVELOPE_COORDINATE_SYSTEM
to the reader COORDINATE_SYSTEM
prior to applying the envelope.
Required/Optional
Optional
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE_COORDINATE_SYSTEM <coordinate system>
Workbench Parameter
Search Envelope Coordinate System
CLIP_TO_ENVELOPE
This directive specifies whether or not FME should clip features to the envelope specified in the SEARCH_ENVELOPE
directive.
Values
YES | NO (default)
Mapping File Syntax
<ReaderKeyword>_CLIP_TO_ENVELOPE [yes | no]
Workbench Parameter
Clip To Envelope
ALIAS_MODE
This directive allows the user to specify what kind of alias handling should be performed. See the Workbench Reader Parameters for more details.
Required/Optional
Optional
Parameter
<alias_mode>
Values
NONE (default) | SCHEMA | ON_DATA_FEATURES
Workbench Parameter
Alias Mode
