Garmin MPS Writer Parameters
Output File Parameters
The value for this parameter is the length of GPSBabel-generated short names. The default is 10.
Note that values smaller than 10 may cause issues with duplicate names.
Set this parameter to Yes to allow whitespace in generated short names. The default is set to No.
The value for this parameter is the version of MPS to write.
The valid values are 3, 4, and 5; the default is 5.
