Reader Directives
The directives listed below are processed by the Garmin GDB reader. The suffixes shown are prefixed by the current <ReaderKeyword> in a mapping file.
By default, the <ReaderKeyword> for the Garmin GDB reader is GARMIN_GDB.
DATASET
The value for this directive is the Garmin GDB file to be read.
Required/Optional
Required
Mapping File Syntax
GARMIN_GDB_DATASET /usr/data/data.gdb
