Garmin GDB Writer Parameters
Output File Parameters
Category
The value for this parameter is the GDB category to assign to waypoints.
The valid range is 1 to 16. This range represents the 16 user-defined categories available on Garmin GPS devices.
Bitmap of Categories
The value for this parameter is a mask that represents multiple categories to assign to each waypoint.
The valid range is 1 to 65535 or 0x0001 to 0xFFFF.
Version
The value for this directive is the version of GDB to write.
The valid range is 1 to 3, and the default is 2.
