This wizard pane allows you to specify the connection parameters for the FME Server you wish to connect to. Workbench provides two connection methods for FME Server connections:
For more information regarding connection types and credentials, contact your System Administrator.
Proxy ServerYou can specify a proxy server for the FME Server web connection:
Host: The hostname of the FME Server to which you want to connect.
Port: The port of the FME Server to which you want to connect. The default port is 7071.
URL: The URL of the FME Server to which you want to connect.
Username: The username for the FME Server login account.
Password: The required password for the account.
| Dialog Buttons | |
| Test... | The Test... button at the bottom of the dialog allows you to test the FME Server connection parameters. |
| Defaults |
The Defaults button allows you to override the default connection parameters with your own, or reset the connection parameters to the default. Save as My Defaults: Choose this option to save connection parameters for all the fields on the page. Reset to My Defaults: If previously saved defaults in this field have been edited, you can reset your own defaults. |
Click the Next button.
Note for versions FME 2012+: If you try to publish to an older version of FME Server, you will see a warning indicating that certain features may be lost or not be available.
