FME Form: 2025.1 BETA
Menu Commands and Shortcuts
See also Workbench Keyboard Shortcuts for an additional list of shortcuts.
File
Command | Keyboard Shortcut – Windows | Keyboard Shortcut – Mac | Function |
New | Ctrl n | ⌘ n | Opens the Create Workspace dialog, which provides different options for creating a new workspace. |
Open | Ctrl o | ⌘ o | Opens a file browser so you can pick an FME workspace (.fmw ) file. |
Open Recent | Opens a recently-opened workspace. | ||
Compare Files |
CtrlAltc |
Option⌘c |
Allows you to view the differences between two workspaces. For more information, see Comparing Workspaces or Custom Transformers |
Save | Ctrl s | ⌘ s | Saves the current workspace. |
Save As | Shift ⌘ s | Saves the current workspace to a different name. You can also save a simple workspace to an .fmx file for use with the Transformer Designer. | |
Save As Template | Saves the current workspace as a template (.fmwt). | ||
Export as Custom Transformer | Exports the workspace as a custom transformer. | ||
Export As Custom Format | Exports the workspace as a custom format. | ||
⌘ p |
Previews and prints the workspace. Tip To print only a portion of a workspace, click and drag to select items on the canvas before previewing. To preview and print the entire workspace, toggle the Print Selected Only icon on the Print Preview toolbar. To fit a large workspace (or selection) to one page, select the Fit to Page icon.
Send To (Windows only) | Opens your e-mail client with the current workspace attached to a new e-mail. | ||
Close File | Ctrlw | ⌘w | Closes the current workspace. |
Exit FME Workbench(Windows only) |
Ctrl q | Quits FME Workbench. |
Mac-Only
Command | Keyboard Shortcut | Function |
About FME Workbench | Displays information about this installation of FME Form. | |
Preferences | ⌘ , |
Opens FME Options. |
Licensing Assistant | Opens the FME Form Licensing Assistant. | |
Check for Updates | Opens the Software Update tool. | |
Services | Allows you to configure Mac services as they apply to FME Workbench. | |
Hide FME Workbench | ⌘ h | Hides the FME Workbench window. |
Hide Others | Option ⌘ h | Hides all windows except FME Workbench. |
Show All | Shows all open windows. | |
Quit FME Workbench | ⌘ q | Quits FME Workbench. |
Edit
Undo | Ctrl z | ⌘ z | Reverses the most recent action in a workspace. |
Redo | Ctrl y | Shift ⌘ z | Repeats the most recent action that you reversed in a workspace. |
Show Edit History | Shows the Edit History Window. | ||
Cut | Ctrl x | ⌘ x | Cuts a selection and sends it to the clipboard. |
Copy | Ctrl c | ⌘ c | Copies a selection and sends it to the clipboard. |
Paste | Ctrl v | ⌘ v | Pastes a selection from the clipboard. |
Delete | Del | Delete | Deletes a selection. |
Select All | Ctrl a | ⌘ a | Selects all content on the canvas. |
Start Dictation (Mac only) | fn fn | Enables dictation. | |
Emoji & Symbols (Mac only) | ^ ⌘ space | Opens an emoji selector. |
View
Window Layout |
Provides options to show, hide, or save the following parts of the user interface:
Start Tab | Shows/hides the Start Tab. | ||
Status Bar | Shows/hides the Status Bar. | ||
Toolbar | Shows/hides the Toolbar. | ||
grids |
Displays the Grid and Guides dialog:
Tip To temporarily disable Snap to Grid while dragging, hold the Ctrl key. |
Zoom to Full Extents |
Fits the workspace into the available canvas area. |
Maximize Canvas | Shift F11 | Shift F11 | Maximizes the canvas to the size of the current window. |
Full Screen | F11 | F11 | Maximizes the canvas to the size of the screen. |
Restore FME Default View |
Resets windows to the FME Workbench default layout. |
Enter/Exit Full Screen (Mac only) | Maximizes/reverts the FME Workbench window. |
Build
Generate Workspace | Ctrlg | Shift⌘n | Opens the Generate Workspace dialog. |
Readers |
Provides options related to readers:
Writers |
Provides options related to writers:
Transformers |
Provides options related to Transformers:
Manage User Parameters |
Opens the User Parameters dialog. |
Show Navigator |
Shows the Navigator window. |
Show Transformer Gallery |
Shows the Transformer Gallery window. |
Show Parameter Editor |
Shows the Parameter Editor window. |
Show Feature Type Connections |
Shows the Feature Type Connections window. |
Show Attribute Connections |
Shows the Attribute Connections window. |
Test
Run Workspace |
F5 |
F5 |
Runs the workspace with existing parameters. |
Rerun Entire Workspace |
ShiftF5 |
ShiftF5 |
Runs the entire workspace. If Data Caching is enabled, all caches are regenerated, including up-to-date ones. |
Run Selected |
When data caching is enabled, runs a selected portion of the workspace, depending on which option is specified. For more information, see About Data Inspection. |
Prompt for Parameters |
CtrlAltF5 |
Option⌘F5 |
Enables the feature that prompts you to change parameters when running workspaces (for example, if you want to use different source data). |
Enable Data Caching |
CtrlF5 |
⌘F5 |
Runs the workspace in Data Caching mode. All links and ports display feature counts. |
Enable Record Counting |
Enables record count display. |
Stop at Breakpoints |
CtrlShiftF5 |
⌘ShiftF5 |
Runs the translation Using the Breakpoint Inspector, after you define a breakpoint. |
Enable Performance Profiling |
Produces a performance report of the workspace. See Monitoring Workspace Performance |
Enable All Inspectors | Enables all Inspector transformers. | ||
Redirect Writers to Data Inspection | Redirects the output to the FME Data Inspector. | ||
Remove |
Removes any of the following from the workspace: A list of the selected items that are in the workspace appears. For large lists, use the search filter to display. Use the checkboxes to delete the desired objects, and click OK. |
Show Data Preview and Record Information |
Shows the Data Preview and Record Information windows. |
Show Schema Preview |
Shows the Schema Preview window. |
Show Translation Log |
Shows the Translation Log window. |
Show Breakpoint Inspector |
Shows the Breakpoint Inspector. |
Organize
Attributes | Expands/collapses all attributes. | ||
Bookmarks | Expands/collapses all bookmarks. | ||
Annotations |
Shows/hides attached or summary annotations. Attached annotations are defined by the user, while summary annotations display a box that contains information about the feature type or transformer. |
Bring to Front/Send to Back | Brings objects forward on the canvas or sends them behind other objects. | ||
Align | Aligns selected objects on the canvas with one another, according to the specified orientation. | ||
Size | Adjusts selected objects to have a minimum width, or have enough width to fit the object's text. | ||
Spread | Evenly spaces selected objects on the canvas from one another, either horizontally or vertically. | ||
Auto-Organize |
Optimizes the layout of objects on the FME Workbench canvas. |
Deploy
Publish to FME Flow | Publishes a workspace to an FME Flow. Note that you must have an FME Flow configured as part of your system. | ||
Republish to FME Flow | Republishes a workspace to an FME Flow. Note that you must have an FME Flow configured as part of your system. | ||
Download from FME Flow | Downloads a workspace from an FME Flow. Note that you must have an FME Flow configured as part of your system. | ||
Download from FME Flow Data Virtualization |
Downloads a workspace from FME Flow Data Virtualization. |
Batch Translation |
Runs the translation in batch mode. |
Utilities
FME Options |
Ctrl, |
Opens FME Options for configuring FME default settings. |
FME Account |
Allows you to log in or out of an FME account. |
License Borrowing |
Allows floating license holders to temporarily use another floating license. For more information, see License Borrowing |
Browse FME Hub |
Opens FME Hub. |
Browse Readers and Writers |
Opens the Reader and Writer Gallery. |
Browse Coordinate Systems |
Opens the Coordinate System Gallery. |
Browse Geographic Transformations |
Opens the Geographic Transformation Gallery. For more information, see Geographic Transformations and Predefined Datums. |
Purge Temporary Files |
Purge temporary FME Workbench-related files. |
Open Cache Folder |
Opens the folder where temporary data caches are stored. |
Open FME Data Inspector |
Opens the FME Data Inspector. |
Help
Show AI Assist |
Shows the AI Assist window. |
Examples |
Opens the Examples Gallery. |
FME Help |
Opens the FME Help viewer. |
Keyboard Shortcuts |
Ctrl/ |
Opens the FME Workbench Keyboard Shortcuts page. |
FME Community |
Opens the FME Community page. |
FME Academy |
Opens the FME Academy page. |
FME Support Center |
Opens the FME Support Center page. |
Check for Updates (Windows only) |
About FME Form (Windows only) |
