PointCloudComponentRenamer
Renames an existing component.
- Renaming components to meet processing or format requirements.
The PointCloudComponentRenamer receives point cloud features, changes the names of selected existing components, and then outputs the modified point cloud feature.
Components may be renamed to standard component names or user-defined names. If a target component name (the new name) is already in use, that component will be overwritten.
Multiple components may be renamed at once.
In this example, we are starting with a text file (CSV) of cell signal measurements. We want to convert the entire dataset to a single point cloud.
Note that coordinates are available in the longitude and latitude attributes, however, the data is non-spatial at this point.
In order to treat the dataset as a point cloud and be able to perform spatial manipulations (such as reprojection), two steps are required.
First, the text records are routed into a PointCloudCombiner, where they are converted into a single point cloud feature.
Next, a PointCloudComponentRenamer is used to change the longitude and latitude values to x and y components - and so as individual point coordinates within the point cloud.
Step 1 - Conversion to Point Cloud
In the parameters dialog of the PointCloudCombiner, most of the input features’ attributes are kept by specifying them in the Attributes to Preserve as Components table. This will retain individual values on each point within the point cloud, including coordinates.
A single point cloud feature is output, but it does not yet have point geometries inside the point cloud. Note that the extents are nan, nan - meaning not a number.
Step 2 - Rename Coordinate Components
In the parameters dialog of the PointCloudComponentRenamer, we rename the longitude and latitude components to x and y - the standard coordinate component names.
Standard names are available on the Target Component’s drop-down menu.
The output point cloud feature now contains points and has valid extents.
The original CSV text file is now a point cloud, and may be passed along for further processing. Note that it does not have a z component, which could be created and set to zero (0) if necessary with a PointCloudComponentAdder.
- To duplicate a component and its values with a new name, use the PointCloudComponentCopier.
Point cloud features with component names altered as specified in the parameters.
MISSING_FEATURE_COMPONENTS
Each line in this table specifies a component to be renamed and its new name. Multiple components may be renamed.
Source Component |
The source component name. Standard component names may be selected from the drop-down menu, whereas user-defined names are entered directly. |
Target Component |
The target component name. If this component already exists, it will be overwritten. Standard component names may be selected from the drop-down menu, whereas user-defined names are entered directly. |
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History |
Search for all results about the PointCloudComponentRenamer on the FME Community.
