GoogleCloudStorageConnector
Accesses the Google Cloud Storage file storage service to upload, download, or delete files and folders or list file/folder information from a Google Cloud Storage account.
- Manage datasets on Google Cloud Storage by uploading, downloading, and deleting files and folders
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
- Read downloaded Google Cloud Storage data using the FeatureReader, or upload data written by the FeatureWriter to Google Cloud Storage
- Retrieve file and folder names, paths, links and other information from Google Cloud Storage to use elsewhere in a workspace.
The GoogleCloudStorageConnector uses the Google Cloud Storage account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on the specified action, it will upload or download blobs and attributes; list information from the service; or delete blobs from the service. On uploads, link attributes can be added to the output features. On List actions, file/folder information are added as attributes.
In this example, the GoogleCloudStorageConnector is used to download an Esri Geodatabase from Google Cloud Storage. After creating a valid web connection to a Google Cloud Storage account (which can be done right in the Account parameter), and browsing to the geodatabase folder, the Bucket and Path to the object is retrieved, and a destination for the download is selected.
A FeatureReader is added to read the newly downloaded dataset. Here, the PostalAddress feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the geodatabase will be refreshed every time the workspace is run.
In this example portion of a workspace, the GoogleCloudStorageConnector is used to download a raster orthoimage from Google Cloud Storage into an attribute.
The file is read from Google Cloud Storage, and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
- This transformer cannot be used to directly move or copy files between different Google Cloud Storage locations. However, multiple GoogleCloudStorageConnectors can be used to accomplish these tasks.
- The FeatureReader can access Google Cloud Storage directly, without using the GoogleCloudStorageConnector. In this case, a permanent local copy of the dataset will not be created.
The output of this transformer will vary depending on the action performed.
- After an Upload action, selected information about the file will be available as attributes.
- A Download action will output the incoming feature and can save to either a file, folder or attribute.
- A Delete action will output the incoming feature.
- A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the GoogleCloudStorageConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
The GoogleCloudStorageConnector can use credentials from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create a Google Cloud Storage connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Project ID | The Google Cloud project id. Only required when the credential source is Web Connection. |
Action |
The type of operation to perform. Choices include:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Delete Options
Bucket | The bucket the file or folder is in. If valid credentials have been provided as a web connection, you may browse for a bucket. |
Path | The full path of a file or folder on Google Cloud Storage to delete. If valid credentials have been provided as a web connection, you may browse for a location. |
Download Options
Path | The full path of a file or folder to download. If valid credentials have been provided as a web connection, you may browse for a location. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. |
Response Body Encoding |
For Download as Attribute, you can specify a character set encoding to ensure the output is in a human-readable form. If Auto Detect from HTTP Header is specified but there is no encoding in the Content-Type metadata associated with the data, the output will be returned as raw bytes. |
Download to Folder | Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
If File Exists |
Specify what to do if the file already exists locally. Valid for Download as File or Folder.
Include Subfolders | Choose whether to download subfolders of the Google Cloud Storage source or not. Valid for Download as Folder only. |
Output Attributes
The selected attributes will be added to the output feature.
_download_path |
Path of the downloaded object on the local file system. This attribute will not be added for Download as Attribute. |
List Options
Bucket | The bucket the folder is in. If valid credentials have been provided as a web connection, along with a valid project id, you may browse for a bucket. |
Path | The full path to the folder to list. If valid credentials have been provided as a web connection, you may browse for a location. The project id is not required to browse paths in a valid bucket. Buckets are uniquely named and are associated with projects. |
Include Subfolders | If set to Yes, then subfolders are recursively traversed, and their contents are included in the result. |
Output Attributes
_name |
Name of the file or folder |
_full_path |
Full path of the file or folder |
_url |
URL to the file or folder. |
_file_or_folder |
Whether the item is a file or a folder |
_file_size |
File size (not present for folders) |
_created |
Date and time when the file was created |
_last_modified |
Date and time when the file was last modified |
_relative_path |
Path to the item relative to the list path |
Data Source
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
File to Upload |
The file to be uploaded to Google Cloud Storage if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to Google Cloud Storage if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
Upload Options
Bucket | The bucket the folder is in. If valid credentials have been provided as a web connection, you may browse for a bucket. |
Path | The full path to the folder on Google Cloud Storage to upload to. If valid credentials have been provided as a web connection, you may browse for a location. |
Upload with File Name | The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
If File Exists |
Specify what to do if the file already exists on Google Cloud Storage.
Permissions |
Specify access rights to the uploaded file or folder.
Metadata
It is possible to specify custom name-value pairs that are associated with the uploaded features.
Output Attributes
The selected attributes will be added to the output feature. Only available for file and folder uploads.
_name |
Name of the file or folder. |
_full_path | Full path of the file or folder. |
_url |
Dialog Options - Tables
Dependencies | Google Cloud Storage Account |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | Released FME 2019.0 |
Search for all results about the GoogleCloudStorageConnector on the FME Community.
