GoogleCloudPubSubConnector
Connects to the Google Cloud Pub/Sub service to create topics and subscriptions or send and receive messages.
- Processing of event logging
- Interoperability with Big Data analytics platforms
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from the subscription.
- After a Send action, output features represent messages sent to the topic.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the GoogleCloudPubSubConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
Required for authentication. Using a web connection integrates best with FME, but in some cases, you may wish to use a key file.
Account |
Available when the credential source is Web Connection. To create a Google Cloud connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools > FME Options... > Web Connections. |
Project ID | The Google Cloud project ID. |
Action |
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Subscription
Subscription |
The subscription to subscribe to messages. A topic can have multiple subscriptions. |
Create Subscription |
If Yes is selected, the subscription will be created automatically with the following subscription options. |
Create Subscription Options
Topic |
The topic to subscribe to. |
Acknowledgment Deadline (secs) |
The approximate amount of time that the service waits for the subscriber to acknowledge receipt of the message before resending. The default and minimum is 10 seconds. The maximum is 10 minutes. |
Receive Messages Options
Mode |
Two message receiving options are available:
Max Number of Messages |
In Batch mode, up to the specified number of messages. Often the service will return less. |
Encoding |
By default, the _value attribute contains the raw bytes received from the server. If an encoding is selected, the connector will instead attempt to decode the value of received message to a string using the selected encoding. |
Topics
Topics |
The topics where the message is sent. Multiple topics are space separated. |
Create Missing Topics |
If Yes is selected, topics will be created automatically if they do not exist. |
Send Messages Options
Message Value |
The actual message data. This must be a string or binary value. The value must match the encoding type. |
Encoding |
The encoding of the message value. The encoding must be appropriate for the message value. |
Attributes |
Additional attributes for the message. An attribute has a key and a value, which may be text strings or byte strings. |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_id |
The id of the message |
_value |
The value of the message |
_timestamp |
The message creation timestamp. Note that timestamps for sent messages are not available. |
_partition |
The partition the message is stored in |
_attributes{}.name |
Structured list attributes containing the header keys and values of a received message. Note that the order of attributes may be arbitrary. |
Dialog Options - Tables
Dependencies | Google Cloud account |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | Released FME 2019.0 |
Search for all results about the GoogleCloudPubSubConnector on the FME Community.
