AzureQueueStorageConnector
Accesses the Azure Queue Storage service to send or receive messages.
- Aggregation of data from queues and other message streams
- Trigger an action from a message
The AzureQueueStorageConnector uses your Azure Storage account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the queue storage service.
- The queue storage service xml encodes and decodes messages in utf-8 by default
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from the queue.
- After a Send action, output features represent messages sent to the queue.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the AzureQueueStorageConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
Required for authentication. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create an Azure Storage connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Account Name | Available when the credential source is SAS or Embedded. An account name and either an account key or a shared access signature can be specified directly in the transformer. |
Account Key | Available when the credential source is Embedded. An account name and access key can be specified directly in the transformer instead of in a web connection. |
Shared Access Signature (SAS) | Available when the credential source is SAS. An account name and shared access signature can be specified directly in the transformer. |
Action |
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Action > Action parameter. Parameters for each Action are detailed below.
Deletes messages from the queue.
Delete Messages Options
Queue |
The queue to delete messages from. A queue can be entered manually, or selected interactively by clicking the ellipses. |
Delete all Messages |
If Yes, all messages in the queue will be removed. If No, the message with the specified ID and POP receipt will be removed. |
Message ID |
Required for deleting a message. Retrieved from a previous receive operation. |
POP Receipt |
Server Timeout (seconds) |
The maximum time to wait for the server to complete the requested operation. |
Receives messages from the front of the queue without altering the visibility of the messages.
Peek Messages Options
Queue |
The queue to peek at messages from. A queue can be entered manually, or selected interactively by clicking the ellipses. |
Number of Messages |
The number of messages to peek from the queue. |
Receives messages from the front of the queue.
Receive Messages Options
Queue |
The queue to receive messages from. A queue can be entered manually, or selected interactively by clicking the ellipses. |
Mode |
Two message receiving options are available:
Specifies the number of messages to read for the operation. For Stream mode, this is the number retrieved per poll interval. For Batch mode, this is the total number retrieved. |
Poll Interval (seconds) |
When mode is Stream, the period to wait between receiving messages. |
Delete on Receive |
If Yes, then delete the messages as soon as they are received from the queue. If No, the messages can be received again after the visibility timeout. |
Visibility Timeout (seconds) |
The time the message is invisible. After the timeout expires, the message is visible. The default is 30 seconds. |
Send Messages Options
Queue |
The queue to send messages from. A queue can be entered manually, or selected interactively by clicking the ellipses. |
Content |
An encoded message. The default encoding is a xml unicode string. |
Update Messages |
If Yes, update a message in the queue service. This operation can be useful to “lease” a message if the workspace has not finished processing. The invisibility of a message can be extended by updating the visibility timeout. |
Message ID |
Required for updating a message. Retrieved from a previous receive operation. |
POP Receipt |
Time to Live Expiry |
If Yes, set the time that the message lives for. If No, the message never expires. |
Time to Live (seconds) |
How long the message lives. The default and maximum is 7 days. After the specified time, the message is permanently removed from the queue. |
The time the message is invisible. After the timeout expires, the message is visible. The default is 0 seconds. |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_id |
The id of a message. Required for updating and deleting. |
_value |
The message content. |
_dequeue_count |
The number of times a message has been retrieved, either from a peek or receive operation. |
_expiration_time |
The time the message expires in unix time. |
_pop_receipt |
The POP receipt of a message, obtained from a receive operation. Required for updating and deleting. |
_time_next_visible |
The time the message is next visible in unix time. |
_timestamp |
The time the message was created in unix time. |
Dialog Options - Tables
Dependencies | Azure Storage account |
FME Licensing Level | FME Base Edition and above |
Aliases | MicrosoftAzureQueueStorageConnector |
History | Released FME 2019.0 |
Search for all results about the AzureQueueStorageConnector on the FME Community.
