AzureComputerVisionConnector
Accesses the Azure Computer Vision Service to detect objects in images.
Submitting text to the Azure Computer Vision service to
- detect individual objects
- describe the general contents
The AzureComputerVisionConnector uses your Azure Cognitive Services account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the service.
It will submit images to the service, and return features with attributes that describe the contents of the image. Services supported are object detection, text detection, and face detection.
- For object detection, if the service is able to identify the exact location of an object in the image, a bounding box geometry will also be returned.
- Text detection will always return bounding boxes around the detected text.
- For face detection, if the service is able to identify the exact location of a face in the image, a bounding box geometry will also be returned. There is also the option to detect and locate facial landmarks.
- For better performance, requests to the Computer Vision service are made in parallel, and are returned as soon as they complete. Consequently, detection results will not be returned in the same order as their associated requests.
- While powerful, the use of AI has important legal and ethical implications. Consult your local AI legislation and ethical guidelines before applying the AzureComputerVisionConnector in a production environment. For information about privacy and compliance with respect to Azure Cognitive Services, please see https://azure.microsoft.com/en-ca/support/legal/cognitive-services-compliance-and-privacy.
This transformer accepts any feature. Raster geometries may be used as input if Raster Geometry is selected as the image source.
Note: The AzureComputerVisionConnector does not support coordinate systems.
Output will depend on the analysis chosen. Each input feature may result in multiple output features. For example, a single image is likely to contain multiple detectable objects.
Object Detection
Successfully identified objects will result in output features with attributes describing the objects. A bounding box geometry may also be returned, with a separate confidence value. Each input image may result in several detection features. Bounding boxes are in pixel units, and will align with the input.
Attributes
_label |
A word or short phrase describing the content of the image. Labels may be general descriptors for the image, or may refer to identifiable instances in the image. For example, a label of "Vegetation" with no bounding box indicates that there are plants somewhere in the image. A label of "Abies" with a bounding box might indicate that there is a fir tree in the top left corner. |
_confidence | A number between 0 and 100 that indicates the probability that a given prediction is correct. |
Text Detection
Successfully identified text will result in output features with attributes describing the text. Features will be output for lines of text, and for individual words in each line. Each feature will have a bounding box for the line or word.
When using a local file or raster geometry or URL as input, the bounding box is in pixel units, and will align with the input.
Attributes
_text | The detected text in the line or word. |
_type |
The type of detected text. Lines are sections of text that are aligned along the same horizontal axis. Sentences may be split across multiple lines. Words are sections of text separated by whitespace, and are associated with parent lines. Options: LINE, WORD |
_id | The number identifying the feature. If the feature represents a line of text, the identifier is unique within the image. If the feature represents a word, the identifier is unique within the parent line. |
_parent_id | The _id value of the row the word is in. This value will be null for rows. |
Face Detection
Successfully identified faces will result in output features with attributes describing the face. A bounding box geometry will also be returned, with a separate confidence value. Each input image may result in several detection features. Bounding boxes are in pixel units, and will align with the input.
Attributes
The following attributes are returned:
_age, _gender, _smile, _emotion_anger, _emotion_contempt, _emotion_disgust, _emotion_fear, _emotion_happiness, _emotion_neutral, _emotion_sadness, _emotion_surprise, _facial_hair_beard, _facial_hair_moustache, _facial_hair_sideburns, _head_pose_pitch, _head_pose_roll, _head_pose_yaw, _glasses, _hair_bald, _makeup_eye, _makeup_lip, _accessories{}.type, _accessories{}.confidence, _blur_level, _blur_value, _exposure_level, _exposure_value, _noise_level, _noise_value, _hair_color{}.value, _hair_color{}.confidence
Output will depend on the analysis chosen. Only one output summary feature will be produced per input feature.
Object Detection
A summary feature with the original geometry and attributes preserved will always be output through the Summary port. Attributes will be added to indicate the labels that apply to the image in general, and not to a specific area.
Attributes
_labels{}.confidence | A number between 0 and 100 that indicates the probability that a given label is correct. |
_labels{}.name | A word or phrase describing the content of the image. |
Text Detection
A summary feature with the original geometry and attributes preserved will always be output through the Summary port. Attributes will be added to indicate the number of lines and words detected.
Attributes
_detected_words | The number of words that were detected in the image. |
_detected_lines | The number of lines of text that were detected in the image. |
Face Detection
A summary feature that contains details on the total amount of faces that were detected in the image.
Attributes
_detected_faces | The number of faces that were detected in the image. |
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the AzureComputerVisionConnector already having a value for fme_rejection_code, this value will be removed.
To use the AzureTextAnalyticsConnector or the AzureComputerVisionConnector you will need a Cognitive Services Account, then generate an endpoint and key to authenticate through our connectors.
Credential Source |
The AzureComputerVisionConnector can use credentials from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create a Azure Cognitive Services connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Endpoint and Secret Key | Available when the credential source is Embedded. An endpoint and secret key can be specified directly in the transformer instead of in a web connection. |
Image Source |
Where to get the input image for detection. Options are:
Input Filename | If Local File is selected for the image source, the path to the JPEG or PNG file to use. |
URL | If URL is selected for the image source, the source URL to use. |
Detection Type |
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Detection Type parameter. Parameters for each Detection Type are detailed below.
Object Detection Options
Object detection does not require any additional parameters.
Text Detection Options
Text Analysis Language |
The language to be detected. The language code must be used for the attribute value (for example, “en”). Use “Unknown [unk]” for automatic language detection. |
Face Detection Options
Output Facial Landmark Points |
Whether to include information about facial landmarks in output features. |
Dialog Options - Tables
Dependencies | Azure Cognitive Services Account |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | Released FME 2019.2 |
Search for all results about the AzureComputerVisionConnector on the FME Community.
