PointCloudSimplifier
Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.
- Reducing the data volume of a point cloud feature to meet processing or storage requirements, when honoring the overall shape of the original dataset is desirable.
The PointCloudSimplifier receives point cloud features and outputs them with fewer points than the original. The points to keep are identified by an algorithm that determines the overall shape of the point cloud, and then selectively discards points.
Areas with high rates of change (such as steep slopes) will have more points kept, and areas with low rates of change (generally flat areas) will be thinned more aggressively. This is based on the Medial Axis Transform (MAT) of the original, a representation like a skeleton of the entire point cloud feature. Individual points are considered against the MAT and evaluated for inclusion or exclusion.
The manner of generation of the MAT, method of sampling, and desired level of simplification can be optionally adjusted through parameters.
Both the simplified point cloud and a new point cloud feature containing all removed points are output.
Note: Medial Axis Transform (MAT) Simplification. This method estimates normals for each point and uses a ball-shrinking algorithm to approximate the MAT. Then it samples the point cloud based on each point’s Local Feature Size (LFS), defined by the shortest distance from the point to the medial axis. Points in areas of high curvature (low LFS) are sampled at a higher density than redundant low curvature (high LFS) points.
In this example, we will reduce the number of points in a point cloud, while honoring the original shape of it.
Note that the source dataset has over 6 million points in it. Viewed here in the FME Data Inspector at an oblique angle, we can see that it contains a number of tall structures in a fairly flat area.
The point cloud feature is routed into a PointCloudSimplifier.
In the parameters dialog, the default settings are kept.
The output point cloud has been reduced to just over 1.6 million points. Note that areas with rapid elevation change - the structures - remain largely intact, whereas large flat areas with little change in elevation have been thinned much more aggressively.
Compare the point cloud before and after simplification:
- This transformer is very processing intensive. The PointCloudThinner also reduces the number of points in a point cloud, using either regular sampling intervals or first/last x points. It is much faster than the PointCloudSimplifier, but does not consider the shape of the feature.
Merges component values from one point cloud to another. Features that contain the desired components are connected through the Supplier port, and the features that will receive the components are connected through the Requestor port. |
Sorts a point cloud by the values of components. |
Applies transformations on a point cloud. Applying a transformation is primarily done for compatibility with other processing and writers that cannot support the transformation natively. For example, the LAS reader produces Int32 coordinates with a scale and offset. However, the POINTCLOUDXYZ writer cannot support component scale/offsets, so the transformation will be applied. The resulting coordinates will be Real64 with no transformation. Note that processing and writers that cannot support transformations will apply them automatically, but this transformer can be used to manually apply the transformation if desired. |
Point cloud features with a simplified subset of the original points.
Point cloud features containing all points not included in the simplified point cloud.
INVALID_PARAMETER_<KEYWORD>
NO_RESULT
| Algorithm | Medial Axis Transform: Perform simplification based on the Medial Axis Transform (MAT). This method estimates normals for each point and uses a ball-shrinking algorithm to approximate the MAT. Then it samples the point cloud based on each point’s Local Feature Size (LFS), defined by the shortest distance from the point to the medial axis. Points in areas of high curvature (low LFS) are sampled at a higher density than redundant low curvature (high LFS) points. |
| Filter Ratio |
Specifies the desired level of simplification, relates LFS values to sampling density. Higher values will result in lower overall density. Typical values range from 0.01 to 0.8. |
| Minimum Sampling Density |
Specifies the minimum sampling density for grid cells (in points per square unit). A value of 0 means that the sampling density is not bounded from below. This can be useful to maintain a minimum level of detail in nearly flat regions which would otherwise be removed entirely because of plane detection. |
| Maximum Sampling Density |
Specifies the maximum sampling density for grid cells (in points per square unit). A value of 0 means that sampling density is not bounded from above. |
| LFS Based Simplification |
Linear: Use the unmodified LFS values for each point during simplification. Quadratic (LFS^2): Use the square of the LFS value for each point during simplification. This will increase the effect that curvature has on point sampling. |
| Tuning and Noise Reduction |
| Advanced |
Dialog Options - Tables
Search for all results about the PointCloudSimplifier on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
