PointCloudReplacer
- Restoring point clouds previously extracted into an attribute by the PointCloudExtractor, often used to store point clouds as Blobs in non-spatial databases.
- Creating geometry from point clouds read with an AttributeFileReader transformer.
The PointCloudReplacer receives features of any geometry type (or no geometry) that have point clouds stored as Blob attribute of the feature, most often a result of having previously used the PointCloudExtractor to store them as Blob attributes to meet format or processing requirements.
The format of the encoded Blob point cloud must be provided.
In this example, we will retrieve and decode a point cloud that was previously encoded with a PointCloudExtractor and loaded to a non-spatial database.
A database reader (PostgreSQL, in this case) reads the feature from the database table, which is then routed into a PointCloudReplacer.
Examining the feature as it exits the database reader, note that it has no geometry.
The first two attributes - _pointcloudblob and _pointcloudformatname - contain the encoded point cloud as a Blob, and the name of the encoding (LAZ) used for the point cloud. Both of these attributes were originally created by the PointCloudExtractor.
In the PointCloudReplacer’s parameters dialog, Format is set to LAZ, and Blob Attribute is set to _pointcloudblob.
The output feature now has point cloud geometry. Note that the Blob attribute also still exists, and could be removed with an AttributeRemover or AttributeManager to improve performance.
- This transformer only works with point cloud formats. Use the GeometryReplacer for vector formats or the RasterReplacer for raster formats.
Merges component values from one point cloud to another. Features that contain the desired components are connected through the Supplier port, and the features that will receive the components are connected through the Requestor port. |
Sorts a point cloud by the values of components. |
Applies transformations on a point cloud. Applying a transformation is primarily done for compatibility with other processing and writers that cannot support the transformation natively. For example, the LAS reader produces Int32 coordinates with a scale and offset. However, the POINTCLOUDXYZ writer cannot support component scale/offsets, so the transformation will be applied. The resulting coordinates will be Real64 with no transformation. Note that processing and writers that cannot support transformations will apply them automatically, but this transformer can be used to manually apply the transformation if desired. |
Features with point clouds stored as attributes.
Features with their geometry replaced by the decoded point clouds.
Features without a valid, decodable point cloud in the specified Blob Attribute will be routed to the <Rejected> port.
INVALID_FEATURE_CANNOT_READ_BLOB
Format |
The point cloud format used to decode the Blob. Choices include:
Blob Attribute |
The attribute from which the blob will be read. |
Dialog Options - Tables
Search for all results about the PointCloudReplacer on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
