AttributeDecompressor
Decompresses and decrypts the values of the specified attributes that were compressed by the AttributeCompressor.
- Decrypt password-encrypted values that were previously encrypted by the AttributeCompressor
- Decompress XML or large geometries that were previously compressed by the AttributeCompressor
The AttributeDecompressor lets you pick one, some, or all attributes on incoming features to be decompressed. If the compressed attributes have been encrypted, the password can be provided to decrypt them. Features passing through the transformer are output with their attribute names unchanged, selected values decompressed, and other values intact.
In this portion of a workspace, data with a geometry attribute that was previously compressed by the AttributeCompressor has been read, and needs to be used. The compressed data is contained in the _geometry attribute, and was originally encoded as OGC Well Known Text (WKT).
After reading the features, they are passed to the AttributeDecompressor for interpretation. The compressed attribute is selected, and there is no encryption. Character encoding is left as default.
At this point, the geometry is still an attribute, but has been decompressed and is readable. The next step is to use a GeometryReplacer to create the geometry, which can now be used elsewhere in the workspace.
- The AttributeDecompressor uses the zlib library to provide basic compression, and the OpenSSL library to provide encryption.
Features with attributes that were compressed and/or encoded by the AttributeCompressor.
All attributes, with specified attributes decompressed.
Attributes to Decompress |
After connecting the transformer, click the browse button to select the attributes to be decompressed and/or decrypted. |
Character Encoding for Decompressed Attributes |
The decompression/decryption algorithms produce a string of bytes. Use this parameter to instruct the transformer how to interpret those bytes. If an encoded attribute was compressed in the AttributeCompressor transformer, this parameter should be set to the same encoding. |
Encryption Type |
Use this parameter to select an encryption type. Currently, only the AES-256 encryption algorithm is supported. |
Password |
If encryption is being used, the value of this parameter will be used to generate an encryption key. This must be the same value used to encrypt the attribute values in the AttributeCompressor transformer. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
Search for all results about the AttributeDecompressor on the FME Community.
