AreaGapAndOverlapCleaner
Repairs area topologies by resolving gaps and overlaps between adjacent areas. An overlap occurs where two or more areas intersect each other, creating an region covered by multiple areas. A gap occurs where two or more areas fail to meet at a boundary.
The AreaGapAndOverlapCleaner cleans gaps and overlaps by constructing a 2D planar partition from the input areas using the specified tolerance.
Example
- Requires valid area geometries. For example, self-intersecting, or degenerate areas will not be properly repaired.
- All overlaps will be cleaned, even if they are larger than the tolerance.
- The AreaGapAndOverlapCleaner resolves gaps and overlaps between adjacent areas. If a single area is input, it will be output unchanged.
- The AreaGapAndOverlapCleaner may create spikes when merging large overlaps to adjacent areas. However, spikes smaller than the tolerance will never be created. If these spikes are not desired, try increasing the tolerance.
- Donut holes, if not filled by another area, are gaps in the 2D planar partition.
Only area geometries are accepted as input.
Features that have been cleaned are output via this port.
Geometries that collapsed within tolerance will be output via the Remnants port. Additionally, features that did not have any geometry left after overlap resolution will also be output via this port with null geometries.
Features with invalid geometries will be rejected and output via this port. Additionally, if the Repair Method parameter is Priority (Edge Preserving) or Priority (Area Enlarging), features with invalid priority attributes will also be rejected via this port.
INVALID_PARAMETER_PRIORITY_ATTRIBUTE
| Group By | The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
| Group By Mode |
| Tolerance |
The minimum distance between geometries in 2D before they are considered equal, in ground units, during construction of the 2D planar partition. If the tolerance is Automatic, a tolerance will be estimated based on machine precision at the location of the input geometries. |
| Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. With this setting, the transformer might output more features than were given as inputs. Reject: Do not process aggregates and output them via the <Rejected> port. |
| Connect Z Mode |
If applicable, select a method for handling z values. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
| Measures/Z Conflict Value |
This parameter specifies how to deal with geometries that have a measure, but are missing at least one value, or that have z values, but are missing at least one value. None (Drop Values): Remove incomplete measures or z values. Compute: Look at the values on either side of the missing value, and compute an estimate. Custom Value: The missing values are filled in with the specified custom default value. |
| Treat Measures as | When using the Compute mode to compute missing measure values, measures can be considered Continuous, and linearly interpolated from their neighbors, or they can be Discrete, and taken exactly from the nearest neighbor. |
| Fill All Gaps |
Yes: All gaps in the 2D planar partition will be filled. No: Only gaps within the tolerance will be filled. |
| Repair Method |
Specifies how to resolve gaps and overlaps once the planar partition has been created. Given the following input:
| Priority Attribute |
The Priority Attribute should be a non-negative integer value, with 0 meaning highest priority. It is enabled when the Repair Method parameter is Priority (Edge Preserving) or Priority (Area Enlarging). |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
Yes |
| Dependencies | |
| Aliases | SliverRemover |
| History | |
| Categories |
Search for all results about the AreaGapAndOverlapCleaner on the FME Community.
