Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format.
The raster format used to decode the blob.
The attribute from which the blob will be read.
If this parameter is set to Yes, the Blob Attribute will be removed from the resulting feature.
Note that this transformer only works with raster formats. Use the GeometryReplacer for vector formats or the PointCloudReplacer for point cloud formats.
This transformer is typically used to restore a raster previously extracted into an attribute by the RasterExtractor.
Associated FME function or factory: @GeometryFormat
Tags Keywords: raster geometry database extract replace blob serialize
