Serializes the geometry of the feature into the Blob Attribute based on the selected writer format.
The raster format used to encode the blob.
An attribute to preserve the specified format value for future use.
The attribute that will contain the resulting blob.
Note that when writing the Blob Attribute, you may need to adjust the attribute type to an unbounded data type to avoid truncation of the blob.
Please choose an appropriate attribute type depending on the destination format. For example, an appropriate attribute type for SQL Server is "image".
Associated FME function or factory: @GeometryFormat
