Serializes the geometry of the feature into the Blob Attribute based on the selected writer format.
The point cloud format used to encode the blob.
An attribute to preserve the specified format value for future use.
The attribute that will contain the resulting blob.
Note that when writing the Blob Attribute, you may need to adjust the attribute type to an unbounded data type to avoid truncation of the blob.
FME Factory Used: @GeometryFormat
