Teradata Non-Spatial User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
| Name | The name of the field to be written. |
| Type |
This format supports the following field types. bigint Represents 64-bit signed integers, in the range of 2^63+1 to 2^63-1. blob Represents a variable length Binary Large Object (BLOB), used to store binary data of up to 2097088000 bytes. byte Represents a fixed-length binary object up to a length of 64000 bytes. byteint Represents a 8-bit (1-byte) signed integer, in the range of 128 to 127. char Represents a fixed length character string. The maximum length depends on the server character set: 32000 bytes (KANJISJIS) or 32000 characters (UNICODE/GRAPHIC) or 64000 characters (LATIN). clob Represents a variable length Character Large Object (CLOB), up to a length of1048544000 characters for UNICODE server character set, or 2097088000 characters for LATIN server character set. date Represents date data from January 1, 0001 to December 31, 9999. See Standard FME Date and Time Format. decimal Represents a decimal number with a fixed number of up to 38 digits. float Represents a 64-bit floating precision number. int This type is used to represent 32-bit signed integers from 2^31+1 to 2^31-1. json Represents text or binary JSON documents. If the storage format is text, the maximum length is 16776192 LATIN characters or 8388096 UNICODE characters. If the storage format is BSON or UBJSON, the maximum length is 16776192 bytes. number Represents a fixed or floating point decimal. smallint This type is used to represent 16-bit signed integers from -2^15+1 to 2^15-1. time This type is used to represent time data with an accuracy of up to 1 microsecond. See Standard FME Date and Time Format. timestamp This type is used to represent date and time data from January 1, 0001 to December 31, 9999 with an accuracy of up to 1 microsecond. See Standard FME Date and Time Format. timestamptz This type is used to represent date and time with time zone data and an accuracy of up to 1 microsecond. See Standard FME Date and Time Format. timetz This type is used to represent time with time zone data in the range of 00:00:00 to 24:00:00. See Standard FME Date and Time Format. varbyte Represents a variable-length of binary data up to a length of 64000 bytes. varchar Represents variable-length character data. The maximum length depends on the server character set: up to a length of 32000 bytes (KANJISJIS) or 32000 characters (UNICODE/GRAPHIC) or 64000 characters (LATIN). xml Represents XML content of up to 2 gigabytes. |
| Index |
The types of indexes and constraints to create for the column. Indexes and constraints are created only if the table is created. Each index and constraint contains only one column. The valid values for the column type are listed below: PrimaryIndex: Applies primary index constraint. PrimaryIndexNotNull: Applies primary index and non-nullable constraints. PrimaryKeyNotNull: Applies non-nullable and unique constraints on a column that is used as a primary key for the table. Only one primary key is allowed per table. UniqueNotNull: Applies non-nullable and unique constraints. NotNull: Applies non-nullable constraint. |
