NMEA 0183 Reader Parameters
The date to assume for tracks that do not have a date. The value is in the form of YYYYMMDD.
This parameter must be specified in order to read datasets containing undated track points.
Schema Attributes
- In a non-dynamic scenario, you can use this parameter to expose additional attributes on multiple feature types.
