MapInfo Extended TAB Quick Facts
Format Type Identifier |
MAPINFO_EXTENDED |
Reader/Writer |
Both |
Licensing Level |
Base |
Dependencies |
None |
| Format Restrictions |
Available on:
Dataset Type |
File |
Feature Type |
File base name |
Typical File Extensions |
.tab (.dat, .id, .map, .ind) |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
Yes |
Spatial Index |
Always |
Schema Required |
Yes |
Transaction Support |
Geometry Type |
mapinfo_type |
| Encoding Support | Yes |
MapInfo Extended TAB Geometry Support
Geometry |
Supported? |
| aggregate |
yes |
circles |
yes |
| circular arc |
yes |
donut polygon |
yes |
elliptical arc |
yes |
ellipses |
yes |
line |
yes |
none |
yes |
point |
yes |
polygon |
yes |
raster |
no |
solid |
no |
surface |
no |
text |
no |
z values |
no |
