Hierarchical Data Format 4 (HDF4 Hyperion) Quick Facts
Format Type Identifier |
HDF4_HYPERION |
Reader/Writer |
Reader |
Licensing Level |
Professional and above |
Dependencies |
None |
Dataset Type |
Reader: File |
Feature Type |
HDF4_HYPERION, <source_dataset_filename>, <subdataset_name>, or <source_dataset_filename_subdataset_name> |
Typical File Extensions |
.L1R |
Automated Translation Support |
User-Defined Attributes |
Through TAB files |
Coordinate System Support |
Yes |
Generic Color Support |
Spatial Index |
Never |
Schema Required |
Transaction Support |
Encoding Support |
Geometry Type |
hdf4_hyperion_type |
Hierarchical Data Format 4 (HDF4 Hyperion) Geometry Support
Geometry |
Supported? |
aggregate |
no |
circles |
no |
circular arc |
no |
donut polygon |
no |
elliptical arc |
no |
ellipses |
no |
line |
no |
none |
no |
point |
no |
polygon |
no |
raster |
yes |
solid |
no |
surface |
no |
text |
no |
z values |
no |
Hierarchical Data Format 4 (HDF4 Hyperion) Raster Support
Band Interpretations |
UInt8, Int16, Real32 |
Palette Key Interpretations |
UInt8 |
Palette Value Interpretations |
RGB24, RGBA32 |
Nodata Value |
none |
Cell Origin (x, y) |
0.5, 0.5 |
Rotation Support |
Yes |
GCP Support |
Yes |
World File Support |
TAB File Support |
Yes |
