IBM DB2 Non-Spatial (JDBC) User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
| Name | The name of the field to be written. |
| Type |
This format supports the following field types. This type is used to represent 64-bit signed integers. This type is used to represent variable length binary data up to a length of 2,147,483,647 bytes. This type is used to represent fixed-length character data up to a length of about 254 bytes depending on the DB2 hosting platform. This type is used to represent variable-length character data up to a length of 2,147,483,647 bytes. This type is used to represent date data from January 1, 0001 to December 31, 9999. This type is used to represent variable-length double-byte character data up to a length of 1,073,741,823 characters. This type is used to represent fixed precision and scale numeric data from 1-10^31 to 10^31-1. This type is used to represent 64-bit floating precision numbers. This type is used to represent fixed-length double-byte character data up to a length of 127 characters. Requires the database to be UTF-8 encoded. This type is used to represent 32-bit signed integers. This deprecated type is used to represent variable-length character data up to a length of 32,700 bytes. Use varchar or clob instead. This deprecated type is used to represent variable-length double-byte character data up to a length of 16,350 characters. Requires the database to be UTF-8 encoded. Use vargraphic or dbclob instead. This type is used to represent 32-bit floating precision numbers. This type is used to represent 16-bit signed integers. This type is used to represent time data in the range of 00:00:00 to 24:00:00. This type is used to represent date and time data from January 1, 0001 to December 31, 9999 with variable precision. This type is used to represent variable length character data up to a length of about 32,672 bytes depending on the page size of the table space and the DB2 hosting platform. This type is used to represent variable length double-byte character data up to a length of about 16,336 characters depending on the page size of the table space and the DB2 hosting platform. Requires the database to be UTF-8 encoded. This type is used to represent XML documents and fragments. |
| Index |
The types of indexes and constraints to create for the column, if the table is created. Each index and constraint contains only one column. The valid values for the column type are listed below: NotNull: A non-nullable constraint. |
