You are here: New formats for 2018 > FME Augmented Reality (AR) Writer > Feature Types > FME Geometry Attributes Supported
                                        These are attributes that map to the FME geometry model.
| Attribute Name | Value | More Information |
| fme_texture_coordinate_x fme_texture_coordinate_y fme_texture_coordinate_z | These are named measures that hold texture coordinates on the vertices of obj_face.
 | Texture Coordinates |
| fme_vertex_normal_x fme_vertex_normal_y fme_vertex_normal_z | These are the named measures that hold obj_face vertex normal components. | Vertex Normals |
