You are here: Reference Manual > FME Server Web Services > Transformation Services > Data Streaming Service > Web Application Properties
                                        Data Streaming Service Properties File Content
                                        #                       Stream Download Servlet configuration file
                                        # This file details the installation parameters of the Stream Download Servlet.
                                        # SERVER_NAME - The computer where the Transformation Manager is running. Can be specified
                                        #               as a network name (ie: "ATHENA") or an IP. The default value is
                                        #               "localhost".
                                        SERVER_NAME={SAFE{fmeserverHostnameLocal}}
                                        # SERVER_PORT - The port on which the Transformation Manager is running on the remote
                                        #               machine. This is an integer between 1025 and 65535.
                                        #               The default value is the default Transformation Manager listening port,
                                        #               which is 7071.
                                        SERVER_PORT={SAFE{fmeserverRequestPort}}
                                        # CONNECTION_POOL_EXPIRY - The length of time in seconds in which an FME Server connection remains idle
                                        # 										 		 before expiring from the connection pool.
                                        #                          If a value of less than or equal to zero is specified, then there is no
                                        #                          connection pooling.
                                        CONNECTION_POOL_EXPIRY=300
                                        # RESOURCE_PATH - This is the path to the textual resources of the log.
                                        #                 This file stores all the messages that will appear in the
                                        #                 log as well as their code.
                                        RESOURCE_PATH={SAFE{resourcesDir}}
                                        # MIN_TIME_BETWEEN_REQS - This is the minimal amount of time that a client
                                        #                         must wait before sending another request. If a
                                        #                         request is sent before that interval, it will be
                                        #                         ignored. The time is specified in milliseconds.
                                        MIN_TIME_BETWEEN_REQS=1000
                                        # LOG_CONFIG_PATH - The folder path that contains the log file configuration.
                                        LOG_CONFIG_PATH={SAFE{utilitiesDir}}/config
                                        # LOG_FILE_NAME - The file name that the log files will have in common.
                                        LOG_FILE_NAME=datastreaming.log
                                        #DEFAULT_RESPONSE_FORMAT - The default response format
                                        DEFAULT_RESPONSE_FORMAT=HTML
                                        #DEFAULT_USER_ID - The default user ID to log in FME Server
                                        DEFAULT_USER_ID=guest
                                        #DEFAULT_PASSWORD - The default password for default user ID
                                        DEFAULT_PASSWORD=guest
                                        #SECURE_CLIENT_ADDRESS - A boolean value that determines if token authentication includes the client
                                        #                        address. Set it to true if enhanced security is required. The default value
                                        #                        is false.
                                        SECURE_CLIENT_ADDRESS=false
                                        #SECURITY_CLIENT_ID - The client ID assigned to this web service.
                                        SECURITY_CLIENT_ID=service_fmedatastreaming
                                        #REQUEST_DATA_DIR - The directory which stores request data from HTTP POST body
                                        REQUEST_DATA_DIR={SAFE{requestDataDir}}
                                        #ENGINE_SUBSECTION - The subsection name used for workspace transformation
                                        ENGINE_SUBSECTION=STREAM_DOWNLOAD_SERVICE
                                        #LOCALE_CONFIG_PATH - the path to the FME localization config file which contains the FME_LOCALE property
                                        #          If no file path or an invalid file path is specified, then the default system locale is used.
                                        #          If a valid file path is specified, the FME locale in the specified file is used.
                                        #          If there is no FME_LOCALE property in the file, then the default system locale is used.
                                        #          The language, country and variant are separated by underscores.
                                        #          Language is always lower case, and country is always upper case.
                                        #					 Examples: "en", "de_DE", "_GB", "en_US_WIN", "de__POSIX", "fr__MAC"
                                        LOCALE_CONFIG_PATH={SAFE{resourcesDir}}/fmeLocaleConfig.txt
                                        #FAILOVER_SERVER_NAME - (Optional) The name of the FME Server host that is designated for failover.
                                        #                        If connection to the primary FME Server is lost, the Service will attempt to connect
                                        #                        to the specified FME Server host that is designated for failover.
                                        #                        To use FAILOVER_SERVER_NAME below, uncomment the line and replace <failoverServerName> with
                                        #                        the FME Server failover host name. Do not include the angle-brackets in the failoverServerName.
                                        #                        For example: FAILOVER_SERVER_NAME=fmecore2
                                        #FAILOVER_SERVER_NAME=<failoverServerName>
                                        # These are optional notifications that can be configured for this Servlet.
                                        # The general configuration format is NOTIFY_<keyword>=<topic_name>.
                                        # NOTIFY_SYNC_JOB_SUCCESS - This generates a notification for all successful synchronous (blocking) jobs.
                                        # NOTIFY_SYNC_JOB_FAILURE - This generates a notification for all failed synchronous (blocking) jobs.
                                        NOTIFY_SYNC_JOB_SUCCESS=
                                        NOTIFY_SYNC_JOB_FAILURE=
                                        # CORS Shared Configuration File - File system path to the configuration file for cross-origin resource sharing that
                                        #                                  is itself shared by all FME Server services.
                                        CORS_SHARED_CONFIGURATION_FILE={SAFE{resourcesDir}}/clients/cors.properties
                                        ################### Stream Download Servlet configuration file END #####################
