Data Upload Service
Users can upload source data or other file-based resources for FME Server Workspaces.
In the FME Server Web User Interface, File Upload is available for any workspace with a published parameter that represents a file used by the workspace. For more information, see Uploading Data Files.
Note: When working with .zip files, we recommend using modern zip utilities that support Unicode file names. If file names are not in Unicode, you can specify the DEFAULT_ZIP_CODEPAGE web application property.
Once data is uploaded, users can select the uploaded data for the workspace to use. Uploaded files are stored in a private location accessible to FME Server but not the user.
Shelf Life of Uploaded Files
By default, files are deleted 1 day after they are uploaded. To change, update task Delete_DataUpload_Files on the System Cleanup page of the Web User Interface. For more information, see Cleaning Up FME Server Logs and Other Files.
Request Elements
Supported Request Methods
This section describes the various methods available for interacting with the Data Upload service. The methods supported for sending files are PUT and POST. The HTTP GET method is supported for browsing files that are already uploaded.
Remember that only volatile storage is supported and that all requests must be associated with an FME Server workspace.
Request |
Request Description |
HTTP Method |
Target URI |
Upload a single file |
You can upload a file using the HTTP PUT method. |
PUT |
http://host[:port]/fmedataupload/<repository>/<workspace>/<filename> |
Upload a single file or multiple files |
You can upload a single file or multiple files using a simple form submission that uses the HTTP POST |
POST |
http://host[:port]/fmedataupload/<repository>/<workspace> |
Browse Uploaded Files |
You can acquire a listing of all uploaded files for a session by making a GET request to either the same URI used to upload files originally, or, in the case of archives, append to this an archive file and/or a file path within the archive for a listing of files there. You can use the optional path component at the end to show the contents of a sub-folder within an archive file. To report just the root contents of the archive file, omit the optional path part. For example, the request URI /fmedataupload/Samples/austinWFS.fmw/myfile.zip/pictures/ |
GET |
http://host[:port]/fmedataupload/<repository>/<workspace>/<archive file name>/[<filename or path within archive>] |
Service Specific Request Parameters
Name |
Value |
Description |
opt_fullpath |
true | false |
When enabled the service response includes the physical or absolute path for each file that the FME Engine can use. |
opt_extractarchive This parameter is not available in HTTP GET because extracting archives is an operation and not a state flag. |
true | false |
When enabled the service extracts uploaded zip files and returns the file contents inside of zip files. |
opt_responseformat |
xml | json |
Defines the language of the response. The text must be all lowercase. |
opt_pathlevel |
-1 | 0 | n |
This parameter indicates how many levels of recursion deep to show file and folder information. |
Preserving Session State
Java EE lets you explicitly specify the session ID of a request URL. This specification ensures that the correct session state is preserved for a session when cookies do not work properly or are not available. Simply append the following parameter immediately following the path part of the request URI:
;jsessionid=<session id>
Response Elements
Element |
Child Elements |
Value |
Description |
statusInfo |
status |
success | failure |
The service status |
file, folder, archive |
name |
string |
The name of the file that was uploaded |
size |
long integer |
The size in bytes of the file uploaded.The size element does not apply to folders and is absent beneath folder elements. |
path |
string |
The absolute or physical path of the file (which is used by an FME Engine) |
session |
none |
string |
A session identifier that is always included in each data upload response as an HTTP cookie as well as in the body of the response. |
Note: There will always be a folder node with an empty name attribute. This folder node is the placeholder for the directory that contains the uploaded files for the scope defined by the current user session, workspace name and repository name. This placeholder can be used later when requesting full paths to retrieve the full path to the parent directory for all uploaded files in your scope.
If opt_extractarchive is set to false, the following scenarios results:
- If the requested path inspects the contents of a zip or archive file, then an error response results.
- If the requested path is valid, but the opt_pathlevel is 2 or higher, then a path level of 1 is implied.
