Specifying the FTP Notification
The following reserved keywords can be used in the notification content to modify FTP subscription settings:
ftp_host
ftp_port
ftp_username
ftp_password
ftp_encryption
ftp_transfertype
ftp_destpath
ftp_sourcepath
ftp_connectiontype
- Can be ("Active"
or"Passive"
). Passive Mode requires your FTP server to create connections using port numbers greater than 1023. Active Mode uses only ports 20 and 21 on the FTP server.
Note: File paths must be specified using forward slashes (/) or escaped backslashes (\\).
Note: If a notification message is sent from the FME Server REST API and it contains an unstructured text message, the value of the subscriber_content keyword contains the content of the text message.
Example
Below is an example of notification content for an FTP subscription:
ftp_host : "ftphost",
ftp_port : "21",
ftp_username : "ftpuser",
ftp_password : "ftppassword",
ftp_encryption : "Plain",
ftp_transfertype : "Auto",
ftp_destpath : "/dest/hello/world",
ftp_sourcepath : "D:/test.jpg",
tp_connectiontype : "Active"
to the destination path.
