You are here: Reference Manual > FME Server Web Services > Notification Service > Publishers > Configuring the Publisher
Configuring the IMAP Publisher
- In the FME Server Web User Interface, select Notifications > Publications, and click New.
- Provide a name for the Publication
- In the Protocol drop down menu, select Email (IMAP).
- Specify the Topics you want to publish to using the drop-down selector. To create a topic and use it right away, click +.
- IMAP Server Host: Provide the host name or IP address of the IMAP server.
- Gmail: imap.gmail.com
- Outlook (Live and Hotmail): imap-mail.outlook.com
- Yahoo: imap.mail.yahoo.com
- AOL: imap.aol.com
- IMAP Server Port: Provide the TCP port over which IMAP communication takes place.
- IMAP Email Account/Password: Provide the e-mail address and password of the account receiving e-mails over IMAP.
- Connection Security: Specify the encryption mechanism to use for the IMAP connection. The mechanism selected must work over the specified port.
- Verify SSL Certificate: If Yes, the connection to the specified IMAP Server Host is verified with a valid, signed SSL certificate. If No, the connection is not verified with an SSL certificate. This option is not secure and not recommended unless absolutely necessary, such as when using a self-signed certificate.
- Poll Interval:Specify how often, in minutes, to poll the IMAP server for e-mail.
- Emails to Fetch: If New Emails Only is selected, the publisher fetches only unread messages that were received after the last fetch. If Unread Emails is selected, the publisher fetches every unread Email message in the in-box.
- Filter Type: Allows you to filter out unwanted messages based on content in the subject line. Filter Type can be:
- Simple: A specified string (case-insensitive).
- Regex: A regular expression. For information about creating regular expressions, see https://docs.oracle.com/javase/7/docs/api/java/util/regex/Pattern.html.
- Subject Filter: Provide the filter, according to the specified Filter Type. Wildcard characters are not supported. If blank, no filter is applied, and all unread/new messages are fetched.
- Download Attachments To: Specify a location to download any attachments.
- Browse resources: Select a path in a Resource Management directory.
- Specify a location: Enter your own location. Directory paths must use forward slashes (/) or escaped backslashes (\\).
- Click OK to create the IMAP Publisher.
Note: IMAP access must be enabled in the account settings.
| Protocol | Default TCP Port |
| SSL/TLS | 993 |
| StartTLS | 143 |
| None | 143 |
Note: IMAP access must be enabled on this account.
Note: Each IMAP Publisher created on FME Server must reference a unique e-mail account. You cannot create multiple IMAP Publishers that reference the same address.
