You are here: Administrator's Guide > Securing FME Server > Troubleshooting Active Directory Configurations > SASL Authentication Failure 1
Symptom
An Active Directory connection species SASL as Authentication Methodand GSSAPI as SASL Mechanism, and the following error appears in the log file:
(Active Directory) Exception: "LDAPException(resultCode=82 (local error), errorMessage='An error occurred while attempting to initialize the JAAS login context for GSSAPI authentication: javax.security.auth.login.LoginException: Pre-authentication information was invalid (24) caused by KrbException: Pre-authentication information was invalid (24) caused by KrbException: Identifier doesn't match expected value (906)')"
Or
(Active Directory) Exception: "LDAPException(resultCode=82 (local error), errorMessage='An error occurred while attempting to initialize the JAAS login context for GSSAPI authentication: javax.security.auth.login.LoginException: Client not found in Kerberos database (6) caused by KrbException: Client not found in Kerberos database (6) caused by KrbException: Identifier doesn't match expected value (906)')"
Cause
The user's login password was incorrectly specified.
Resolution
Specify the correct password.
