- Google KML Reader/Writer
- Google KML Quick Facts
- Resource Traversal
- Reader Parameters
- Writer Parameters
- Feature Types
- Writer Pipelines
- Atom Metadata
- Style Management and Common Styles
- Document Element Omission
- Raw Text
- Update Mode
- Feature Representation
- KML Dataset Structure
- File Structure
- Identifying Elements
- Documents and Folders
- Tours
- Extended Data
- User Defined Schema
- Layers and Feature Type Fanout
- Feature Attributes
- Geometry
- 3D
- Fixed Schema
- Common Element Attributes
- Common Format Attributes
- NetworkLinkControl
- Document
- Folder
- Placemark
- ScreenOverlay
- GroundOverlay
- PhotoOverlay
- NetworkLink
- Style
- StyleMap
- Tour
- AnimatedUpdate
- FlyTo
- SoundCue
- TourControl
- Wait
KML Writer Feature Type: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
| Name | The name of the column to be written. |
| Type |
The type of a column in a table. The valid values for the column type are listed below: kml_boolean kml_buffer kml_char kml_date kml_datetime kml_int16 kml_int32 kml_real32 kml_real64 kml_time |
