- Google KML Reader/Writer
- Google KML Quick Facts
- Resource Traversal
- Reader Parameters
- Writer Parameters
- Feature Types
- Writer Pipelines
- Atom Metadata
- Style Management and Common Styles
- Document Element Omission
- Raw Text
- Update Mode
- Feature Representation
- KML Dataset Structure
- File Structure
- Identifying Elements
- Documents and Folders
- Tours
- Extended Data
- User Defined Schema
- Layers and Feature Type Fanout
- Feature Attributes
- Geometry
- 3D
- Fixed Schema
- Common Element Attributes
- Common Format Attributes
- NetworkLinkControl
- Document
- Folder
- Placemark
- ScreenOverlay
- GroundOverlay
- PhotoOverlay
- NetworkLink
- Style
- StyleMap
- Tour
- AnimatedUpdate
- FlyTo
- SoundCue
- TourControl
- Wait
You are here: Popular Formats > Google KML Reader/Writer > Style Management and Common Styles > Unique Id Values
Unique Id Values
The style registry assumes that each style id is unique. Style ids are specified by the kml_id format attribute of features with Style and StyleMap feature types. This includes Style elements created as a result of Common Style' references; the resulting Style element has an id that is the same as the value of the kml_common_style format attribute.
