You are here: Popular Formats > Google KML Reader/Writer > Feature Representation > Placemark > Geometry Attributes
Geometry Attributes
The following FME Attributes can be used to add sub-elements to <Geometry> elements.
Attribute |
Element |
Remarks |
kml_altitude_mode |
<altitudeMode> |
| kml_draw_order | <gx:drawOrder> | (for LineString geometries only) |
kml_extrude |
<extrude> |
kml_gx_altitude_mode |
<gx:altitudeMode> |
kml_tessellate |
<tessellate> |
Note: The KML reader will create geometry traits for the above attributes. The KML writer supports specifying the above attributes using either format attributes or geometry traits.
