Register Services
This page allows you to register your workspace, custom transformer, or custom format with one or more services available on FME Server.
If the service contains configurable parameters, click the Edit... button next to the service you want to configure. For more information, see Edit Service Properties below.
Note: For more information about the FME Server services, see FME Server Services in the FME Server documentation.
Select one or more services and click Publish to publish the workspace to FME Server.
Note: For information on entering workspace process descriptions, see Description in Workspace Properties.
The properties that are available to configure in this dialog depend on which FME Server service you are editing.
