Editing Reader (Source) Feature Type Properties
A Reader feature type represents an existing set of data. Its dialog includes a number of options for managing how the data is read. It also includes a representation of the data schema, which generally you will not need to edit.
Displaying the Feature Type Properties
To display the Feature Type Properties dialog, do one of the following:
- Click the Properties button on the upper right of the feature type
- Right-click on a feature type and select Properties from the menu.
General – Feature Type Name
Editing the feature type name is done by simply clicking in the Feature Type Name field and entering a new value.
Changing this value is rarely necessary because it is meant to reflect (and acts as a filter to) a layer of data in the existing dataset. However, it can be useful when, for example, you are setting up a workspace and do not have access to the original source data.
General – Merge Parameters
For reader feature types, you can specify Merge properties.
User Attributes
Attributes to Read
Note: These options are not available for all formats.
These options allow you to specify the attributes that are read when the workspace is run. Limiting attributes that are read can improve performance and reduce memory consumption.
- All Attributes – Read all the attributes found in the source data when the workspace is run. The attributes read can differ from those displayed under 'Attribute Definition' (see below).
- Exposed Attributes – Read only the attributes that are checked in the Exposed column in the Attributes Definition table.
This table shows the structure of the source data, including attribute names and their types.
Attributes that are checked under Exposed are shown on the canvas and can be referenced from downstream transformers and writer feature types. Unchecked attributes are hidden in the workspace, but are still read at runtime, unless 'Attributes to Read' is set to Exposed Attributes.
This table automatically populates when you add a new reader. If the structure of the source data has changed or is no longer current, you can update it. For more information, see Updating Feature Types.
You can enable the ability to edit the Attribute Definition table. On the Workbench page, check Allow reader feature type editing.
Note: Some readers do not support editing the Attribute Definition table, regardless of this setting.
Format Attributes
Click the Format Attributes tab.
These are built-in FME attributes that you can "expose" or make visible so that you can set them to particular values and connect them to other format-specific attributes. Apply to... exposes the attributes for multiple, selected feature types.
When you select (expose) an attribute on the reader side, it allows its value to be used in the workspace.
If you deselect an attribute, the attribute will no longer be exposed, but it will still be carried on the feature (even though it will be hidden from Workbench schemas).
See About Feature Types and Attributes.
Format Parameters
The parameters here are used to control specific aspects of how the data is read. Not every format has parameters that apply to a specific feature type, in which case this tab will not appear.
Applying Changes to Multiple Reader Feature Types
- Open the Feature Type properties dialog.
- Click the Apply To button, and the Change Multiple Feature Types dialog appears.
- By default, all feature types are listed in the Feature Types to Change field. Click the Browse button to check/uncheck feature types from the feature type list that appears (specify a filter to isolate certain feature types). Click OK to close the list box.
- You can also change merge settings or choose format attributes to expose for the selected feature types.
- Click OK to close the Change Multiple Feature Types dialog.
- To confirm the changes to all feature types, including the current one, click OK in the Feature Type Properties dialog. You will be asked to confirm any changes to other feature types. Note that if you click Cancel, none of the changes will be applied.
