You are here: Workspace Basics > Reading and Writing Data > Feature Types and Attributes > Updating Feature Types
If the structure of the data changes in your workspace (for example, the schema changes or an attribute type changes) you will usually want to keep your workspace up-to-date. This is a particularly useful feature if you are working with databases, or if you are sharing data within a workgroup.
Select Readers > Update Feature Types or Writers > Update Feature Types.
You can also access this feature by right-clicking on the feature type and choosing Update from the command menu.
Click OK to reload the feature type.
