You are here: Workspace Basics > Workbench Interface
FME Workbench Interface
FME Workbench is an application for defining data translation and transformation processes.
With Workbench, underlying FME functionality is exposed in an intuitive interface that allows users to graphically define a custom dataflow from source, through transformation, to destination.
Workbench has tools for defining the source and destination dataset structure (or schema), and also for manipulating the geometry and attributes of spatial data.
Workbench is fully integrated to interact with other FME applications such as the FME Data Inspector and other products such as FME Server, and is the authoring tool for FME Server models.
Menu bar and Toolbar
The menu bar and toolbar contain a number of tools: for example tools for navigating around the workspace, controlling administrative tasks and adding or removing source datasets.
Canvas
The Canvas is where you graphically define your workflow. By default, the workflow reads from left to right; the reader (source data) is on the left, the transformation tools are in the center, and the writer (data destination) is on the right. Connections between each item represent the flow of data and may branch in different directions or even lead to a dead-end if required.
Translation Log
The log pane displays a report on translation results. Information includes any warning or error messages, translation status, length of translation and number of features processed.
Navigator
The navigator is an explorer type tool that displays a text definition of source and destination datasets, plus all the settings that apply to these datasets.
Transformer Gallery
The transformer gallery is a tool for the location and selection of FME transformation tools.
Overview Window
The overview window displays a view of the entire workspace, and highlights the outline of the current canvas window display upon it.
History Window
Lists all edits made to a workspace since it was created or opened. You can preview and revert to an earlier state of a workspace.
Additional viewing options
Additional panes can display lists of feature and attribute connections.
Related Information
Creating Workspaces
About the Workbench canvas.
About the Workbench Navigator.
About  the translation log.
Tell me how to include transformers in my workspace.
Tell me how to manage feature type connections.
Tell me how to manage attribute connections.
