Add Named Database Connection: Named Connections store (in a central location) authentication information associated with a user.
For information about setting up and using named connections, please see:
Select the database to be used. Depending on your database, you may also have to enter a username and password.
Specifies the Oracle database to connect to. This may be a Net Service Name defined in tnsnames.ora or an Easy Connection Identifier. Either form of connection identifier may be prefixed with username and password information.
[<username>[/<password>]@][//]<hostname>[:<port>]/<service_name>.
[<username>[/<password>]@]<net_service_name>
Enter the username and password to access the service.
The name of the Oracle Workspace Manager workspace which will be used by the reader. All tables read by the reader will be read using the same workspace. If this parameter is omitted, or left blank, the default LIVE workspace will be used.
If this checkbox is selected (default), the Oracle database connection remains open for other requestors. A persistent connection is useful for workspaces that are long-running, or published using FME Server.
If this checkbox is not selected, the connection to the Oracle database is closed as soon as possible after data processing is complete.
If selected, the Table List will include tables that live in system schemas or contain special characters like / and $.
Recycled tables (names starting with BIN$) will never be displayed.
Specifies whether to keep the schema qualifier. The full name of a table in an Oracle database is of the format <owner_name>.<table_name>. Selecting this option indicates that the reader should return the table name without any prefixes. This is useful, for example, when creating a workspace that will be passed on to another organization using the same table names.
When this option is selected during the generation of a workspace, the source feature types will be the table names without any prefix; otherwise, they will contain the owner name as a prefix. It is recommended that you do not change this setting after generating the workspace as it is possible for no features to be successfully passed onto the writer (since the writer is expecting feature types with different names).
Note: Even when this option is selected, if the table is owned by a user other than the current user, the <owner_name> prefix will not be dropped. This is to ensure that the reader will find the correct table.
After you have completely specified the database connection, click the Browse button to select tables for import. A connection window appears while the system compiles a table from the database.
Once the table list appears, you can select one or more tables, and then click OK to dismiss the window. The table name(s) will appear in the table list field in the Parameter box.
Enter any SQL where clause that constrains the attributes of the layers selected in the list (for example, NUMLANES=2).
This parameter exposes Format Attributes in Workbench when you create a workspace:
