Licensing options for this format begin with FME Professional Edition.
Oracle Instant Client: Instant Client can be used to run your OCI, OCCI, JDBC, and ODBC applications without installing a full Oracle Client. Instant Client supports SQL*Plus.
The Oracle Non-Spatial Reader/Writer enables FME to read and write attribute data stored using Oracle. This module communicates directly with Oracle for maximum throughput.
Oracle Spatial is also supported by FME:
If only attributes are to be read or written, this Oracle Non-Spatial reader/writer should be used.
Tip: The FeatureReader transformer performs queries against any FME-supported format.
