Licensing options for this format begin with FME Professional Edition.
The Oracle Spatial Relational Reader/Writer module enables FME to read and write geometric and attribute data stored using Oracle Spatial.
This module communicates directly with Oracle Spatial for maximum throughput. Both the relational and object-relational models of Oracle Spatial are supported by FME: the relational model is discussed here and the object-relational model is discussed in a separate chapter – Oracle Spatial Object Reader/Writer.
If only attributes are to be read or written, then the Oracle Non-Spatial reader and writer module should be used.
This chapter assumes familiarity with Oracle Spatial, the geometry types it supports, and its indexing mechanisms.
Tip: The FeatureReader transformer performs queries against any FME-supported format.
