Microsoft Azure Synapse SQL (Data Warehouse) Reader Parameters
Database Connection
Select an existing Microsoft Azure Synapse SQL (Data Warehouse) database connection, or Add Database Connection...
Add Microsoft Azure Synapse SQL (Data Warehouse) Database Connection
To define a new connection from the Connection parameter in a Microsoft Azure Synapse SQL (Data Warehouse) format, see the topic Microsoft Azure Synapse SQL (Data Warehouse): Add Database Connection
Constraints
Use this parameter to expose Format Attributes in FME Workbench when you create a workspace:
  • In a dynamic scenario, it means these attributes can be passed to the output dataset at runtime.
  • In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
