Microsoft Azure Synapse SQL (Data Warehouse): Add Database Connection
To define a new connection from the Connection parameter in a Microsoft Azure Synapse SQL (Data Warehouse) format:
  • Select Add Database Connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections The new connection can be made visible only to the current user, or can be shared among multiple users.
Note  To select an existing, previously defined connection, see the section Reusing a Database Connection in Using Database Connections
Database Connection
Name
Enter a name for the new connection.
Connection Parameters
Server
The host name of the Microsoft Azure Synapse SQL Pool.
Database
To initiate a database connection, enter (or browse for) the database name.
Authentication
  • SQL Server Authentication – Connect using a SQL Server login account, specified through the Username and Password parameters.
  • Microsoft Entra MFA – Connect using a dialog box pop-up that displays the specified username and asks for a password. This method supports multi-factor authentication.
  • Microsoft Entra Password – Connect using an identity that is defined in Microsoft Entra (formerly Azure Active Directory). The Username and Password parameters should match the username and password of the identity in Microsoft Entra.
  • Microsoft Entra Integrated – Connect using the current Windows user identity that is defined in Microsoft Entra (formerly Azure Active Directory). This authentication mode requires the on-premises ​​Active Directory Federation Services (ADFS) to be federated with the Microsoft Entra ID in the cloud.
  • OAuth Connection – Connect using Microsoft Azure Active Directory OAuth 2.0 web service or Client Credentials web service by selecting a Web Connection in the OAuth Connection parameter.
