STAC Asset Reader Parameters
Connection
Use Authentication
Specify the web connection required for browsing the specified data. Only one web connection is allowed.
Note  To add a web connection, select Add Web Connection from the dropdown menu. You can also add web connections from the Workbench Tools menu: select FME Options > Web Connections, then click the + button.
Dataset
Schema Attributes
Spatial
Advanced
