Airtable Writer Parameters
About Web Connections
Connections store authentication information.
For general information about web connections, please see Using Web Connections.
For information about managing web services (including authorization credentials such as Client Id and Client Secret), please see Managing Web Services.
Connection
From the Connection parameter in a web service format, you can do one of the following:
  • Select an existing previously defined connection. For information, see the section Reusing a Web Connection in Using Web Connections.
  • Select Add Web Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users.
Connection
Select an existing Airtable connection, or Add Web Connection...
Add Airtable Web Connection
To define a new connection from the Connection parameter in an Airtable format, see the topic Airtable: Add Web Connection.
Note  Use of the Airtable format requires you to set up your own Web Service. To configure a Web Service, refer to the instructions in the Airtable Web Service template included with this package. (From FME Workbench, open FME Options > Web Connections and click the Manage Services button. Navigate to the Airtable template.)
Service Connection
The name of the Airtable web connection.
Constraints
Base
The ID of the Airtable base to which tables will be written.
After a valid connection has been established, click the browse [...] button to list the Airtable bases which can be accessed using the current credentials.
