Airtable: Add Web Connection
Airtable Authentication
To define a new connection from the Airtable Connection parameter:
  • Select Add Web Connection. See database-specific parameters below, as well as the section To Use a Web Connection in a Workspace in Using Web Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Note  To select an existing, previously defined connection, see the section Reusing a Web Connection in Using Web Connections.
Service Connection
Airtable Connection
Either enter an existing connection name, or, for new connections, refer to the Web Service note below.
Note  Use of the Airtable format requires you to set up your own Web Service. To configure a Web Service, refer to the instructions in the Airtable Web Service template included with this package.
(From FME Workbench, open FME Options > Web Connections and click the Manage Services button. Navigate to the Airtable template.)
