Bentley MicroStation Design (V7) Reader Parameters
Group Elements By
Specifies the overall structure of the schema and data for DGN file reading.
Element Options
The reader can be configured to output all the elements composing cells, or symbols. This is useful if the graphical representation of the Design file is to be preserved. This is true when, for example, a Design file is translated to a GIF image.
Attribute Options
Linkage Extraction
Linkage Extraction boxes allows you to extract MSLinks and/or FRAMME attribute linkage values from the Source Design File. Only the first three linkage values will be extracted.
Model Selection Options
Models and sheets in a Design file can have different spaces, which are essentially the coordinates and units that they represent. This can lead to confusing results if you attempt to view them together in the FME Data Inspector. FME defaults to this combined view, but this parameter allows you to refine the view and read only selected models.
Schema Attributes
Spatial
Coordinate Units By
These parameters control the conversion between UORs in the Design file and FME coordinates. There are three options:
Override Global Origin
These parameters are usually used only when reading Design files that have bad header information. If FME detects a difference between these settings and those read from the Design file, a warning is output to the log file, and these settings take precedence.
Advanced
