GDAL Generic Raster Quick Facts
About Quick Facts Tables
Format Type Identifier
GDAL_GENERIC_RASTER
Reader/Writer
Reader
Dependencies
None
Dataset Type
File
Feature Type
GDAL_GENERIC or <source_dataset_filename>
Typical File Extensions
Varies per format.
See the GDAL format list for details.
Automated Translation Support
Yes
User-Defined Attributes
No
Coordinate System Support
Varies per format.
See Coordinate Systems.
Generic Color Support
No
Spatial Index
No
Schema Required
No
Transaction Support
No
Geometry Type
gdal_generic_raster_type
GDAL Generic Raster Geometry Support
Geometry Supported?
aggregate
no
circles
no
circular arc
no
donut polygon
no
elliptical arc
no
ellipses
no
line
no
none
no
point
no
polygon
no
raster
yes
solid
no
surface
no
text
no
z values
yes
GDAL Generic Raster Support
Band Interpretations
Red8, Red16, Green8, Green16, Blue8, Blue16, Alpha8, Alpha16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64
Palette Key Interpretations
UInt8, UInt16, UInt32
Palette Value Interpretations
RGBA32
Nodata Value
Varies, depending on the GDAL format being read.
Cell Origin (x, y)
Rotation Support
GCP Support
World File Support
TAB File Support
